we are currently testing a quad with 20" Propellers and roughly 10kg TOW
We tuned the copter and it flies quite well but when reaching around 20 - 25m/s vertical velocity it becomes unstable and starts to overract
We had this issue mutiple times and so far were not able to narrow it down - it happens both when flying waypoints, or when flying manually in Loiter Mode
It doesnt seem to be a performance issue, there is still more then enough headroom for the ESCs
BATT_FS_CRT_ACT,1
BATT_FS_LOW_ACT,2
FENCE_ENABLE,1 <- highly recommended for big copters
You have high vibrations with clipping in IMU2 - this could easily be affecting altitude control.
Once you fix the vibrations you can set ATC_THR_MIX_MAN,0.5
The yaw tuning is wrong, the pitch and roll P and I values look way too low too.
Motor thrust expo is wrong.
Harmonic notch filter is not working because of this: INS_HNTCH_REF,0 ← set to 1
and INS_HNTCH_BW probably needs to be about 20 at most, not 30.
Set these again to confirm the filter is actually working as planned
INS_LOG_BAT_MASK,1
INS_LOG_BAT_OPT,4
It is probably worth going back to Initial Parameters in MissionPlanner and start tuning over again, or better → use the Methodic Configurator, and redo all the tuning.
There is a 9 Kg vehicle template in ArduPilot methodic configurator. Use that as staring point and do the changes that @xfacta said when the respective parameters appear on the sequence.
Thanks for the Feedback,
we spent quite some time on the tuning of the system and in manul flight it seems very stable, but obviously we missed something.
Ill double check the values - the Motor thrust expo was determined on Thrust - Teststand so this value should be correct - we currently use Hobbywing DroneCan ESCs
The notch filter is a good input, thanks totaly missed that
something to note is that the system is quite powerful (Hover at ~0.03 Ctun.Tho) , which is why i assume the standard parameters we started with didnt work quite that well
I just double checked in the newest Version i only see one 7kg Template ?
From my limited experience, if copter behaves well in manual (alt hold) mode, but less stable with Loiter, that was due to too low PI, because Loiter reacts much faster than human and tries to overcorrect. If look at the graph you have several instances where the desired pitch oscillates.
Your hover throttle at a roughly constant altitude is about 0.08 or 0.07
Set these:
MOT_HOVER_LEARN,0
MOT_THST_HOVER,0.07
This will start at about the correct level, then check and adjust the hover throttle value over a few flights.
You should probably add a minimum payload to bring the hover throttle up a bit, with the output PWM around 1500, which may give improved control and then Autotune would have a better chance of working properly - after all the other fixes (vibrations for example)
we continued testing and added Dampening to reduce Vibrations as we had very high clipping when the drone started behaving arractic in forward flight however now with dampening and no clipping the drone still reacts exactly the same, staring to pitch down to far and then starts over correcting back until pitch is positive and the drone becomes unstable No damping With Damping
I read mutiple times that large powerful quads might need higher values for
ATC_THR_MIX_MAX
// parameter description recommends thr-mix-max be no higher than 0.9 but we allow up to 5.0
// which can be useful for very high powered copters with very low hover throttle
could this be related to the problem (and how can i test this safely as i dont fully understand the consequences of the value
