Copter 4.1.5 - set to Frame class 10 (Bi-copter)
Can I beg some advice please?
I’m building a bi-copter based on the Matek F765 WSE FC and am having trouble:
- Pitch control makes the tilt servos go in opposite directions to each other, which I’m guessing is wrong. If i reverse one, they both reverse.
- Yaw only works when Armed and throttle raised - is this correct?, but tilt servos move in the same direction, which again seems wrong?
- The servos jitter all over the place when motor throttle is raised - even without props fitted.
Any advise would be greatly appreciated! I’ve built a few quadcopters without too much hassle, but I’m struggling with this bi-copter (especially as there’s precious little info out there about setting them up)5 24-02-2022 21-41-37.bin (546.2 KB)
