maciek01
(Maciek Kolesnik)
December 6, 2023, 2:20am
221
Hopfully this question is not too random for thsi thread.
I also flashed my fc (matek f405-te) with AC 4.4.3 BDshot. And followed setup steps as outlined at the top of this thread.
in messages getgin this output: 12/5/2023 9:17:08 PM : RCOut: DS600:1-2 PWM:3 DS600:4 PWM:5-12
I would expect all 4 servors are DS600. Any clues? there is nothing unusual in my setup
thansks!
hah, just saw this MateksysF405-TE BDshot? - #7 by Kopervlad
investigating …
sounds like i need to avoid channel 3 - wonder how to remap around it… and w/o resoldering the 4 signal wires
Yuri_Rage
(Yuri Rage)
December 6, 2023, 3:10am
222
You only have to change two wires:
Move the ones connected to 2 and 3 over to 6 and 7.
There is really no other solution on that board.
ardupilot/libraries/AP_HAL_ChibiOS/hwdef/MatekF405-TE-bdshot/hwdef.dat at master · ArduPilot/ardupilot (github.com)
ButuzOFF
(Alexander)
December 30, 2023, 8:18pm
223
Hello
I’m using a Skystars F405 Mini HD2 flight controller, but I didn’t find a suitable target in the repository
After reading the forum I tried to assemble the firmware myself
But since there is not enough knowledge, I ran into a problem
I want to implement bidirectional DSHOT, but with these settings, only three motors rotate and transmit telemetry
Please tell me where I made a mistake
SERVO_BLH_AUTO 1
SERVO_BLH_BDMASK 15
SERVO_BLH_MASK 15
SERVO_BLH_OTYPE 5
hwdef.dat
# hw definition file for processing by chibios_pins.py
# Skystars F405HD2 Mini
# MCU class and specific type
MCU STM32F4xx STM32F405xx
# board ID for firmware load
APJ_BOARD_ID 1089
# crystal frequency
OSCILLATOR_HZ 8000000
define STM32_ST_USE_TIMER 5
define CH_CFG_ST_RESOLUTION 32
# reserve 16k for bootloader
FLASH_RESERVE_START_KB 48
FLASH_SIZE_KB 1024
# Motor order implies Betaflight/X for standard ESCs
define HAL_FRAME_TYPE_DEFAULT 12
define HAL_STORAGE_SIZE 15360
STORAGE_FLASH_PAGE 1
# I2C Buses
I2C_ORDER I2C1
PB8 I2C1_SCL I2C1
PB9 I2C1_SDA I2C1
# order of UARTs
SERIAL_ORDER OTG1 USART1 EMPTY USART3 UART4 UART5 USART6
PA11 OTG_FS_DM OTG1
PA12 OTG_FS_DP OTG1
# USART1
PA9 USART1_TX USART1 NODMA
PA10 USART1_RX USART1 NODMA
define DEFAULT_SERIAL1_PROTOCOL 44
define DEFAULT_SERIAL2_PROTOCOL SerialProtocol_None
# USART3 (ESC Telemetry)
PB11 USART3_RX USART3 NODMA
define DEFAULT_SERIAL3_PROTOCOL SerialProtocol_None
# UART4 (GPS)
PA0 UART4_TX UART4
PA1 UART4_RX UART4
define DEFAULT_SERIAL4_PROTOCOL SerialProtocol_GPS
# UART5
PC12 UART5_TX UART5 NODMA
PD2 UART5_RX UART5
define DEFAULT_SERIAL5_PROTOCOL SerialProtocol_None
# USART6 (ELRS)
PC6 USART6_TX USART6
PC7 USART6_RX USART6
define DEFAULT_SERIAL6_PROTOCOL 23
# timer for RC input
PA8 TIM1_CH1 TIM1 RCININT PULLDOWN LOW
# IMU SPI
PA4 BMI270_CS CS
PA5 SPI1_SCK SPI1
PA6 SPI1_MISO SPI1
PA7 SPI1_MOSI SPI1
# Flash logging
PA15 FLASH_CS CS
PC10 SPI3_SCK SPI3
PC11 SPI3_MISO SPI3
PB5 SPI3_MOSI SPI3
# OSD SPI
PB12 OSD_CS CS
PB13 SPI2_SCK SPI2
PB14 SPI2_MISO SPI2
PB15 SPI2_MOSI SPI2
# BARO
PC5 BARO_CS CS
# LED
PC14 LED_BLUE OUTPUT LOW GPIO(0)
PC15 LED_GREEN OUTPUT LOW GPIO(1)
define HAL_GPIO_A_LED_PIN 0
define HAL_GPIO_B_LED_PIN 1
# DMA
DMA_PRIORITY SPI1* SPI3_RX* TIM2* TIM4*
# Motor
PB7 TIM4_CH2 TIM4 PWM(1) GPIO(50) # M1
PB6 TIM4_CH1 TIM4 PWM(2) GPIO(51) BIDIR # M2
PB4 TIM3_CH1 TIM3 PWM(3) GPIO(52) BIDIR # M3
PB3 TIM2_CH2 TIM2 PWM(4) GPIO(53) # M4
# ADC
PC0 BATT_VOLTAGE_SENS ADC1 SCALE(1)
PC1 BATT_CURRENT_SENS ADC1 SCALE(1)
PC2 RSSI_ADC_PIN ADC1 SCALE(1)
# BUZZER
PC13 BUZZER OUTPUT GPIO(80) LOW
define HAL_BUZZER_PIN 80
define HAL_BUZZER_ON 1
define HAL_BUZZER_OFF 0
# SPI
SPIDEV bmi270 SPI1 DEVID1 BMI270_CS MODE3 1*MHZ 10*MHZ
SPIDEV dataflash SPI3 DEVID3 FLASH_CS MODE3 32*MHZ 32*MHZ
SPIDEV osd SPI2 DEVID2 OSD_CS MODE0 10*MHZ 10*MHZ
SPIDEV baro SPI2 DEVID4 BARO_CS MODE0 10*MHZ 10*MHZ
# one IMU
IMU BMI270 SPI:bmi270 ROTATION_NONE
# one baro
BARO BMP280 SPI:baro
define AP_BARO_BACKEND_DEFAULT_ENABLED 0
define AP_BARO_BMP280_ENABLED 1
# enable logging to dataflash
define HAL_LOGGING_DATAFLASH_ENABLED 1
# define default battery setup
define HAL_BATT_MONITOR_DEFAULT 4
define HAL_BATT_VOLT_PIN 10
define HAL_BATT_CURR_PIN 11
define HAL_BATT_VOLT_SCALE 11
define HAL_BATT_CURR_SCALE 31.7
#### COMPASS #######
# no built-in compass, but probe the i2c bus for all possible
# external compass types
define ALLOW_ARM_NO_COMPASS
define HAL_COMPASS_DEFAULT HAL_COMPASS_NONE
define HAL_PROBE_EXTERNAL_I2C_COMPASSES
define HAL_I2C_INTERNAL_MASK 0
define HAL_COMPASS_AUTO_ROT_DEFAULT 2
define OSD_ENABLED 1
define HAL_OSD_TYPE_DEFAULT 1
ROMFS_WILDCARD libraries/AP_OSD/fonts/font0.bin
dkemxr
(Dave)
December 30, 2023, 9:20pm
224
Looks like you were not the 1st to do this:
Skystars F405
andyp1per
(Andyp1per)
December 30, 2023, 9:24pm
225
ButuzOFF
(Alexander)
January 1, 2024, 4:56pm
226
Thank you
Very useful script. I fixed some bugs and added a barometer
All equipment is working normally, motors are spinning
If I turn it on, the three motors work and transmit telemetry. One motor doesn’t work
SERVO_BLH_BDMASK 15
SERVO_BLH_MASK 15
I can’t figure out how to add bidirectional DSHOT to this board
One #M4 motor is on another timer
# MOTORS
PB7 TIM4_CH2 TIM4 PWM(1) GPIO(50) BIDIR # M1
PB6 TIM4_CH1 TIM4 PWM(2) GPIO(51) # M2
PB3 TIM2_CH2 TIM2 PWM(4) GPIO(53) ?? # M4
PB0 TIM3_CH3 TIM3 PWM(5) GPIO(54) # M5
PB1 TIM3_CH4 TIM3 PWM(6) GPIO(55) # M6
hwdef.dat
# hw definition file for processing by chibios_hwdef.py
# for SKYSTARSF405 hardware.
# thanks to betaflight for pin information
APJ_BOARD_ID 1045
# crystal frequency, setup to use external oscillator
FLASH_SIZE_KB 1024
# bootloader takes first sector
define HAL_STORAGE_SIZE 16384
define STORAGE_FLASH_PAGE 1
# SPI devices
# SPI1
PA5 SPI1_SCK SPI1
PA6 SPI1_MISO SPI1
PA7 SPI1_MOSI SPI1
# SPI2
PB13 SPI2_SCK SPI2
PB14 SPI2_MISO SPI2
PB15 SPI2_MOSI SPI2
# SPI3
PB5 SPI3_MOSI SPI3
PC10 SPI3_SCK SPI3
PC11 SPI3_MISO SPI3
# Chip select pins
PC5 BARO_CS CS
PA15 FLASH1_CS CS
PB12 OSD1_CS CS
PA4 GYRO1_CS CS
# Beeper
# SERIAL ports
SERIAL_ORDER OTG1 USART1 USART2 USART3 UART4 UART5 USART6
# PA10 IO-debug-console
PA11 OTG_FS_DM OTG1
PA12 OTG_FS_DP OTG1
# USART1
define DEFAULT_SERIAL1_PROTOCOL 23
# USART2
PA2 USART2_TX USART2
PA3 USART2_RX USART2
# USART3
PB10 USART3_TX USART3
# UART4
PA0 UART4_TX UART4
PA1 UART4_RX UART4
# UART5
PD2 UART5_RX UART5 NODMA
# USART6
PC6 USART6_TX USART6 NODMA
PC7 USART6_RX USART6 NODMA
# I2C ports
I2C_ORDER I2C1
# I2C1
PB8 I2C1_SCL I2C1
PB9 I2C1_SDA I2C1
# Servos
PC9 CAMERA1 OUTPUT GPIO(70) LOW
define RELAY2_PIN_DEFAULT 70
# ADC1
define HAL_BATT_VOLT_SCALE 11.0
define HAL_BATT_CURR_SCALE 34.5
PC2 RSSI_ADC ADC1
define BOARD_RSSI_ANA_PIN 12
# MOTORS
# LEDs
PC14 LED0 OUTPUT LOW GPIO(90)
define HAL_GPIO_A_LED_PIN 90
PC8 TIM8_CH3 TIM8 PWM(7) GPIO(56) # M7
PC15 LED1 OUTPUT LOW GPIO(91)
define HAL_GPIO_B_LED_PIN 91
define HAL_GPIO_LED_OFF 1
# SPI Device table
SPIDEV osd SPI2 DEVID1 OSD1_CS MODE0 10*MHZ 10*MHZ
SPIDEV bmi270 SPI1 DEVID2 GYRO1_CS MODE3 1*MHZ 10*MHZ
SPIDEV dataflash SPI3 DEVID3 FLASH1_CS MODE3 104*MHZ 104*MHZ
# BARO setup
define HAL_BARO_ALLOW_INIT_NO_BARO 1
# One IMU
#IMU Invensense SPI:bmi270 ROTATION_ROLL_180_YAW_90
DMA_NOSHARE TIM4_UP TIM3_UP TIM2_UP SPI1*
DMA_PRIORITY TIM4_UP TIM3_UP TIM2_UP SPI1*
ROMFS_WILDCARD libraries/AP_OSD/fonts/font*.bin
define HAL_DEFAULT_INS_FAST_SAMPLE 3
andyp1per
(Andyp1per)
January 1, 2024, 8:26pm
227
You need to add BIDIR to M4, but you will also need to check the DMA allocation to see if its possible
