I also did a âFollow meâ test today, running Mission Planner on an Android phone & Sik-radio but I got a message something like âFlight mode failedâ and the boat didnât respond whatsoever. I need to dig into the wiki to get this working.
So, another testrun to see where water was coming in the hull. But now, nothing, not a drop entered the boat. Weird.
And the last (early) run before going back to work.
To do:
More waterproofing before I do longer runs.
Smear more epoxy on the inside to protect the wood when water does enter the hull.
Early yesterday morning at around 6:00 AM I took my bigger boat out for a long range maiden. And despite it being terribly tuned, it got home safe after traveling more than 2km. It swerves a lot, and oscillates a lot after a turn. Hopefully I can get a log file while doing some testruns later and see whatâs going on. It is a chonker though, 1.2mtr/4ft and heavy. somewhere between 12-14kg I guesstimate.
Simple edit & parts sped up. At around 450mtr/500mtr TBS CRSF Radio connection was lost:
Ground station hide out, Telemetry on a 3mtr lightstand. So far 1km out and no loss of Telemetry signal. My Radiomaster Radio with TBS crsf where it stood on the table and had connection up to around +450mtr:
Itâs a stabilizer (flybar?) from a large RC helicopter, bought in a fire sale at Hobbyking. Although it might look like it has holes in it, itâs closed up with epoxy
I have one ready to be installed, triggered with an Arduino sensor. The only way water could come in (unless the hull rips open on an iceberg) would be through the prop shaft hole. The prop shaft and keel are completely submerged in epoxy up to almost motor-level. The hatches on top are rubber sealed and will be more securely fixed in the near future.
Iâm not planning to conquer any storms soon, but the boat is built almost submersible.
I installed mine after watching rctestflights video of his solar boat filling with water as even a small leak will sink a boat with enough time. I want to send my boat out to sea so a pump is essential.
Well, I messed up. I tried tuning the boat and it went from terrible to uncontrolable. Stupid me forgot to save the parameters used for the long range run earlier and I ended up with the boat getting stuck under a deck. Got it back by going full throttle backwards, scraping the antenna under the deck and almost capsizing. From there I tried all I could think of and ended with nothing. Iâll have to reset all parameters and start all over again. Which unfortunately wonât be for at least two months. Bummer.
On a positive note, the boat that I started this thread with is navigating almost perfectly. So I do have a back up to play with.
Honestly I donât know. The Bellina is large enough for all electronics if youâre into building your own boat with wood and epoxy so for me the Bellina checks all the marks. Iâve googled many times for an affordable ready-to-go customizable boat/hull but never really found one. Perhaps check your local online market place for someone selling a decent size RC tugboat for cheap?
That large orange boat of mine is an uncut âHappy Hunterâ hull. Large, more than enough room for hours of battery power. But it needs approx. 10Kg of balastâŚ
