Beginner LUA - flight scenarios script
Hello everyone,
I’m a beginner with LUA, I would like to set up flight scenarios with an LUA script, I have some questions so I can’t find the answers:
  • It is noted in the Ardupilot website that LUA scripts are loaded at Ardupilot startup, so should the script be written from the beginning “Arming” until landing?
  • If this is the case how to manage the arming/takeoff/flight/landing and the variables altitudes, speed, waypoints … for a complete mission with LUA?
I found these functions in the documentation:
  • To be used for ARMING ?
– desc
@return boolean
function arming:arm() end
arm() - Attempts to arm the vehicle. Returns true if successful.
  • To be used for TAKEOFF ?
– desc
@param alt number
@return boolean
function vehicle:start_takeoff(alt) end
start_takeoff(altitude) - Begins auto takeoff to given altitude above home in meters. Returns false if not available.
  • Or is it possible to launch a normal mission in AUTO and then load the script during the flight?
    and it will then be possible to trigger certain specific commands according to a certain time by this LUA script ?
Thanks a lot for your help
Nico
Start here:
Thanks Yuri, I don’t know this video, I’ll look at it.
Hi Yuri.
You made me want more F7/H7 boards. :innocent:
If I made you want F7 anything, I’m sorry. Avoid those. They are now relics of the past. Use H7 (or newer when they become available).
