Hello, I am using a Pixhawk 4 mini with the Holybro PM06 V2 power module:
https://holybro.com/products/micro-power-module-pm06-v2
ArduRover version: 4.5.2
I have connected the power module to the pixhawk 4 mini using the (6-pin i believe) cable.
Using a 3s (11.1V) 4000 mAh lipo battery.
In setup I am following the instructions provided with the power module, that says to do folowing:
- Set “Monitor” to: “Analog Voltage and Current”
- Set “Sensor” to: “9: Holybro Pixhawk PM”
- Set “HW Ver” to: “4: The Cube or Pixhwak” (which suppodedly includes the Pixhawk 4 Mini?)"
When I do this the little “Measured Battery Voltage” thing still says 0, and if I dis- and re-connect to the pixhawk (wired mavlink connection) it gives me two errors (see pictures) and some of the settings I made are gone (see other picture).
I am not super expreienced with this entire pixhawk-ardupilot-missionplanner but I have some experience at least.
AFTER RECONNECT:
ERRORS:
Thanks in advance!
