Battery Remain Percent is Always 0%
CubeOrange+ and can-l4-bm are used to create the drone.
The CAN device is (presumably) set up correctly and currently displays current and voltage without any problems, but there is a problem with the battery level always showing 0% (but the arm-check is fine, and the aircraft can fly normally). Perhaps it is simply not set up correctly, but as far as I have been able to find, most of the articles I have looked into have automatically displayed the % when setting the ammeter, and I have not been able to find it. If can-l4-bm is set up correctly, what is the % of the battery based on? Thank you in advance.
Configuration:
Flight Controller: Cube Orange+ and Carrier Board
Ammeter: Matech CAN-L4-BM (Connected to CAN2)
Battery: 2 LiPo batteries 6 cells 12000mAh connected in parallel (should therefore be 6 cells 24000mAh)
Ardupilot: Copter4.4.2
FullParametorList (18.1 KB)
(By the way, the log file cannot be pasted due to the size over, but where is it to be uploaded? Upload a sample flight log file accordingly. thank you.)
Hi. Hello! I have the same problem with the Mateksys CAN-L4-BM model. Does anyone have the solution or can give us a recommendation? Thanks in advance.
Configuration:
Ammeter: Mateksys CAN-L4-BM (Connected to CAN2). Firmware ArduPilot AP_Periph MatekL431-BattMon
Battery: MaxAmps LiPo 62000 18S2P 66.6v Battery Pack
Ardupilot: Mission Planner 1.3.81
Copter 4.5.1
Thanks!
I’ve also got this issue with the same power board, has anyone found a solution? Starting to think it’s an issue with the specific battery monitor.
  • Matek H743-Slim v3
  • Matek CAN-L4-BM
  • 3s 5000mah lipo
