Battery Monitor connected to the wrong CubeOrange power port does not work
Hey Guys - I have a personal project that I’m having an issue with and thought I’d throw it out here to see if anyone has any ideas.
This setup is in a SonicModel AR Wing PRO flying wing that has a cube orange plus on a mini board running Arduplane 4.5.5 and a 6400mah 4S2P Li-Ion battery and the standard power brick.
My problem is that I’m not getting valid battery data on the HUD or data parameters. Screenshots to follow:
IMG_0578-compressed
Hi Bill,
At first glance it looks like you have the correct settings…
Set LOG_DISARMED,1 then plug the battery in for a while - upload that .bin log to a filesharing service (Dropbox, Onedrive…) and send us the link to that log. We will be able to see all the settings and logged voltage values that way.
After that you can set LOG_DISARMED,0
Thanks Shawn, I’ll try to get that logged and uploaded tonight or tomorrow.
change the power port, you connected to the second port not the first.
Andras !! Perfect !! You were absolutely correct. I plugged into power1 and that resolved the issue. Thanks everyone for taking the time to help !!
Bill
