Battery management system
hi all,
I have lithium ion with 6s 21000mAh (tattu) and lithium polymer with 6s 22000mAh (mpower).
I need to read the voltage and the current readings in realtime. So i went through the ardupilot and got this information and I am using lithium polymer tattu brand Tattu Plus DroneCAN Battery — Copter documentation I got to know that I can reading the voltage of each cell, and how much battery voltage is left. I think tattu and tattu plus both are different.
Can anyone say how do i read the voltage and current data of my battery to the log files of my flight controller. And need to get the battery cycle count, so that one can determine the battery life. Is there any possible way to do this?
Configure your vehicle for DroneCAN battery monitor.
can you briefly explain it ?
Read the documentation.
Talk to tattu. There are two versions of those batteries. Only one of then talks ArduPilot droneCAN. Make sure to order the one with the correct firmware
ok thank you that helped a lot
