It was fine before. I use the 90A attopilot … I set to “other” and I adjust my voltage to match my correct voltage.
This always worked for me until 2.74 and up.
I have now tried many settings, nothing is working correctly. it seems to double count the mah used…
I really depend on the batt info, so how can I fix this? any ideas? is it something in the 2.74+ firmware?
The Atto pilot sensor gives current data like analogue RSSI ports. The higher voltage it outputs, the more amps is used.
Like 1V difference on its output means let’s say 25A .
This has not been posted in the issues list on Github that I can see…this bug makes 2.76 unuseable for many people…myself included…having reasonable MAH estimation is a requirement for my FPV distance flying…
Since it seems the new plan is to close these posts with a “solved”, if possible, I will close this.
I have got the batt calc to be reasonable by tweaking the voltage settings in the batt config and choosing “other” for the device instead of what I have which is the 90a attopilot.
