@rubenray,
When in doubt, RTM http://rover.ardupilot.com/wiki/apmrover2-parameters/
There is no “turn speed” parameter in the ArduRover parameter list.
Are you referring to the SPEED_TURN_GAIN parameter?
If so, it is a percentage of the CRUISE_SPEED.
Regards,
TCIII AVD
If you have connected to your boat via the MP GCS your old parameter files will automatically be saved.
As I said in my other post try increasing your NAVL1_PERIOD and see how you go. Otherwise post a dataflash (.bin) log file with logging enabled and we can have a look.
Hi Grant,
I unfortunately had a ‘fly-away’ and it ran aground and seized the outboard motor before I could get to it, but I am back on track with a new motor.
I need to understand this NAVL1_PERIOD a bit better.
Regards
John
