No worries. On the command line in the ArduPilot directory, type ““git submodule update —init —recursive”.
Note that — is two - (not a single long dash).
Perhaps upgrade your bootloader. Download a ph4-mini firmware from firmware.ardupilot.org and flash as a custom firmware in Missionplanner. Then reboot, connect, hit CTRL-F and click the bootloader update button.
I try to do this with the following result.
MP say to me, firmware upgrade not nessesary, because allready on the board.
The Bootloader Upgrade looks like the same. nothing happens.
I try to do this with the no result.
To answer what I think was your question, you can build a bootloader and flash it from the command line, but it’s a bit more complicated to explain how to do it. Missionplanner is easier
BRD_TYPE:24 comes with the Firmware 3.10 or also 3.11.
But the option 24 (PH4-mini) seems to be not known in MP and also QGC.
It seems to be, that the firmware has no option 24 insight. The Bootloader make what? It passes the parameter 24 to the Firmware?
Then the Firmware is not correct in my opinion.
Or is there a problem with the change from IMU-Mask to BRD_TYPE?
So the Bootloader has to be adapted to BRD_TYPE?
The bootloader update should work. You might need to wait a little longer: a message will pop up when it’s complete.
If that doesn’t work, try the latest Missionplanner and see if it’s still an issue
plenty of ways to debug. Firstly, does this happen with a firmware from the groundstation or firmware server, or just when you compile your own?
Also, I did a couple of tests on a Windows machine today. Strangely, I had to run QGroundControl as Administrator to get it to connect. That shouldn’t be necessary, and is likely a permissions issue on the PC I was using, but worth checking.
you here? I’m desperate. (:
What i observe is the following.
QGC has a parameter BRD-TYPE, can you check this parameter and search for an option like PH4 or PH4mini?
I can not find this option.
QGC or MP is the same behavior.
Allen Tseng write, PH4Mini works with beta-3.6.10, i try this and see the same behavior.
I have testet many stables, betas and my own compiled Firmware.
Every time the same behavior.
So i think, there is no support for PH4 today.
Or have i to add a special submodul for PH4?
For me, it looks as if the ardupilot had no support for PH4.
But in the Ardupilot-Firmware-path there is an folder with the name PH4-Mini.
So there is an support allready. I’m confused.
In ardupilot i see the Red LED is blinking after boot up.
So the Problem is not in the GroundControlSoftware.
2.
In PX4 with Attitude Calibration i get the Error: attitude estimator not running - check system boo
And if i make a PreArmCheck i get the error: BaroSensor #0 missing.
I try to change the hardware.
Possible the BaroSensor is damaged.
