Hi i though i give 3.8 a go with new pixhawk 2.1
when i try to arm it i get bad logging error in mission planer so i tried to turn off all loging still the same cant arm the plane
when i try to arm it i get bad log error in mission so i tried to turn off
If you wan to turn off logging, set LOG_BACKEND_TYPE to 0
Setting LOG_BITMASK to 0 doesn’t disable logging.
ok worked it out was bad SD card in a new pixhawk 2.1
