As you can see the vibration levels for the y-axis are going above ±3. What would cause vibrations in only one axis? The x-axis vibrations are well within the acceptable range and I would have thought that the two would mirror one another?
What can I do to reduce the vibrations to withing the acceptable ±3 range?
Ok, that’s a good point I will check if anything is touching the Pixhawk. As for mounting I simply mounted the Pixhawk with the provided foam from 3DR.
