How can I set a passthrough on the AUX channel to default to a certain value while in failsafe?
I can’t seem to figure this out. Setting the radio failsafe doesn’t seem to have any effect as the Throttle failsafe kicks in first.
Any thoughts?
Any thoughts?
Anyone?
I have a liquid spray pump which MUST shut off in the event of signal loss. Seems very strange to me that this is not available (as far as i can tell…)
I attempted to bypass this issue by removing the Throttle based failsafe and setting the Frsky failsafe as follows:
CH5: RTL
CH9 (pump): Off
All other channels set to neutral.
I was hoping this would work, but when tested, the autopilot still enters failsafe and signals “No RC Receiver”. How does ardupilot know this? I can see the outputs from the RC on mission planner and they are correct but I still get this error.
Hi Simone,
Are you using the crop spraying feature?
If yes, then I think the simplest solution (if you’re using master Copter-3.6) is to add a line into the failsafe_radio_on_event to turn off the pump:
sprayer.run(false);
That will handle the RC failsafe. To handle the battery or fence failsafes I think a change would be required in the switches.cpp where it processes the aux switch for the sprayer.
sprayer.run((ch_flag == AUX_SWITCH_HIGH) && !any_failsafe_triggered());
I haven’t tested this but I think it should work.
We are not using the crop sprayer feature currently. The pump is simply manually controlled.
Thank you for the information. If you don’t mind, I would like to get in touch with Peter Barker. Could you send me his email?
Thanks again!
