Hi @bnsgeyer ,
it is possible to do the autotune with an external governor in a gasser helicopter?.
I say this because when the helicopter lands in each setting, the motor will not stop since it will not go through channel 8 of the cube.
Well it will work the same as how you are handling it with auto mode landings. You should really consider using the heliRSC servo output. There have been a lot of improvements to the rotor speed control to include the internal governor.
