I’m trying to autotune my aircraft, its flies fine in all modes but i want to tighten it up as it is sluggish in pitch and yaw. I followed all the steps in the Quaplane VTOL tuning guide (https://ardupilot.org/plane/docs/quadplane-vtol-tuning.html?highlight=tuning). Then i did an autotune starting with roll, that went fine and roll is nice and tight now. I went to pitch next and it did not go well, after two twitches it seems to have lost power and fell to the ground, even with me inputting full throttle. No damage, the next day i tried yaw just to see if it was only the pitch axis with the issue. The same happened, after 2-3 twitches it started to descend and could not catch itself, even with full throttle. Only way to stop the descent is to switch to Q_Stabilized and go to full power.
Its not a battery issue as it flies fine, hovers at approx 50% and i used the same battery for the roll axis tuning. Any help would be great, thanks. Link to log below.
https://drive.google.com/drive/folders/1xUt7-8P6xWJUXZduTMYy_t89jNilBvUa?usp=sharing
