eyesonsky
(eyesonsky)
April 29, 2015, 8:47pm
1
Hi there, I continue some test flight with my new slow fly quadrotor.
I’m facing with a problem never encountered. ( Autotune on my F450 works great)
I try to perform an Autotune to tune this quadcopter perfectly, but It doesn’t work, when I invoke Autotune inflight with my CH7, nothing happens.
I do not understand why and I would like to solve this problem,
Does anyone can explain me the reason or help me to find it ?
Here are my logs :
drive.google.com/open?id=0B5UjD … authuser=0
Thanks !!!
Does anyone can give me an beginning of solution or possible cause??
Have you gone into mission planner and setup switch/channel 7 to autotune?
Sure I have, take a look to my attached img.
in add, got an error in my log when I switch Autotune mod :
27/04/2015 10:54:47 - 043392: Mode Changed to 616
27/04/2015 10:54:47 - 043392: Mode Initialised at 50.033057 5.5083942 Alt: 7.95 Spd:0.29
27/04/2015 10:55:10 - 048701: AUTOTUNE ERROR: Bad Gains (failed to determine proper gains).
27/04/2015 10:55:44 - 056348: AUTOTUNE ERROR: Bad Gains (failed to determine proper gains).
27/04/2015 10:55:47 - 056976: AUTOTUNE_OFF
You can download the full log here : Google drive
Thanks to help me to understand what’s wrong.
pkvaloy
(pkvaloy)
May 4, 2015, 9:57pm
5
I have the exact same issue with version 3.2.1. Autotune engages, but nothing happens - then it switches back off.
Maybe did you can provide your log to compare-it ?
Wich copter did you use ?
Please give me more detail.
Thanks
pkvaloy
(pkvaloy)
May 5, 2015, 8:22pm
7
My copter is a Tarot 650 frame running on 3S with Rctimer motors and 10x5.5 props.
I have successfully autotuned it with an earlier firmware. Which logfiles is of intersest - .log, .bin or .tlog?
Paul
mmm ok so it looks like this is a firmware issue maybe ?
About the log file .log or .bin are ok as well
Alex
Two more flight today ans still can’t perform Autotune , even after make some PID’s change.
Still any help here ?
RabbitStu
(RabbitStu)
May 10, 2015, 7:34pm
10
ch7 doesn’t change for log ending 10-06-35
are you sure your radio is set up properly?
eyesonsky
(eyesonsky)
May 10, 2015, 8:47pm
11
Mmmm you’re right there is something wrong in this way, I will check my radio calibration an configuration .
I will post my feedback after some investigation .
eyesonsky
(eyesonsky)
May 14, 2015, 5:51pm
12
Hello here,
So as promised here is my feedback,
as advised by RabbitStu, I’ve checked the CH7 parameter, ans it was correctly set in MP so I’ve do a nex radio calibration and this solved my problem,
I suspect have forgotten to switch on the ch7 in my first calibration
Anyway this topic is definetly solved but no news from pkvaloy ?
