Old tlog files are getting lost and replaced by PNG files.
If someone wants to check, just try to download any tlog that is older than November.
I have also created a script to check each tlog file available.
#!/usr/bin/env python3
import magic
import posixpath
import requests
from bs4 import BeautifulSoup
ARDUPILOT_AUTOTEST_HISTORY = "https://autotest.ardupilot.org/history/"
def get_all_folders_urls():
page = requests.get(ARDUPILOT_AUTOTEST_HISTORY)
soup = BeautifulSoup(page.content, 'html.parser')
dates_href = [date['href'] for date in soup.find_all('a', href=True) if '2021' in date['href']]
return [posixpath.join(ARDUPILOT_AUTOTEST_HISTORY, date_href) for date_href in dates_href]
def get_all_tlogs_urls(folder_url):
page = requests.get(folder_url)
artifacts_href = [artifact['href'] for artifact in soup.find_all('a', href=True) if artifact['href'].endswith('.tlog')]
return [posixpath.join(folder_url, artifact_href) for artifact_href in artifacts_href]
for folder in get_all_folders_urls():
for tlog_url in get_all_tlogs_urls(folder):
data = requests.get(tlog_url)
print(f"{tlog_url} is a {magic.from_buffer(data.content)}")
https://autotest.ardupilot.org/history/./2021-05-01-07:05/HeliCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-07:05/Rover-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-07:05/ArduPlane-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-07:05/APMrover2-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-07:05/Soaring-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-07:05/ArduSub-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-07:05/QuadPlane-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-07:05/BalanceBot-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-07:05/AntennaTracker-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-07:05/ArduCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-16:05/HeliCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-16:05/Rover-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-16:05/ArduPlane-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-16:05/APMrover2-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-16:05/Soaring-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-16:05/ArduSub-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-16:05/QuadPlane-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-16:05/BalanceBot-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-16:05/AntennaTracker-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-01-16:05/ArduCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-00:05/HeliCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-00:05/Rover-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-00:05/ArduPlane-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-00:05/APMrover2-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-00:05/Soaring-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-00:05/ArduSub-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-00:05/QuadPlane-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-00:05/BalanceBot-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-00:05/AntennaTracker-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-00:05/ArduCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-08:05/HeliCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-08:05/Rover-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-08:05/ArduPlane-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-08:05/APMrover2-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-08:05/Soaring-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-08:05/ArduSub-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-08:05/QuadPlane-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-08:05/BalanceBot-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-08:05/AntennaTracker-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-02-08:05/ArduCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-03-00:05/HeliCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-03-00:05/Rover-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-03-00:05/ArduPlane-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-03-00:05/APMrover2-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-03-00:05/Soaring-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-03-00:05/ArduSub-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-03-00:05/QuadPlane-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-03-00:05/BalanceBot-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-03-00:05/AntennaTracker-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-03-00:05/ArduCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-05-01:05/HeliCopter-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
https://autotest.ardupilot.org/history/./2021-05-05-01:05/Rover-test.tlog is a PNG image data, 600 x 600, 8-bit/color RGB, non-interlaced
