AutoTakeOff: engine starts but only with about 30% power
I have a problem with automatic takeoff with the PX4, version 3.7.1.
If I run with the given 2 m / s, the engine starts but only with about 30% power.
This is of course not enough power and the plane can not take off. What is wrong?
Franz from Germany
Please post a log then we can help.
Also I hate to split hairs but I expect you mean you are having a problem with ArduPilot 3.7.1.
If you are flying the PX4 flight code then you’ll want to use their site for tech support.
in this link https://www.magentacloud.de/share/z-h5ny0y83 the log-file. At approx. 12% you see motor running but only with less power. Normally fullpower is approx. 30 A. I think the problem is a parameter in the configuration and not the hardware.
Thank for all tips.
Franz
A .bin log would be more useful.
Sorry, but where do I found such bin-files?
On the flight controller memory card.
