I have a benchmark mission that I suse to test all new firmware in a flying wing.
In 3.2.0 Autoland without range finder never did the final rotation near ground and model wented in almost straight line to the ground.
In 3.2.1 Autoland without range finder now it beaves like this with same parameter file:
completes misson and goes for landing OK
glides ok without motor until 3-4m high
about 3-4m heigh it gives a little rotation up gaining about 1m more height without motor
it then resumes gliding until ground, but it starts to pull up elevons
Speed reduces and it stalls almost when hitting the ground (wingtip stall)
I send my param file
Do not have logs has my laptop lost battery
Hi, we’d really need logs to be able to help. You should be able to download logs off the board even if they are lost from the GCS.
Have you read the autolanding documentation? plane.ardupilot.com/wiki/flying/ … c-landing/
Cheers, Tridge
the only parameter that interfere with the ‘bump up’ when entering flare seems to be TECS_LAND_DAMP.
I had 0,5 and now going to test with 0,7.
This is strange, because model did this mission +10 times and had always good normal landings.
Since 3.2.1 all landings with same params are now behaving like this.
What happens if you simply lower the flare height?
It sounds like you used to be satisfied with the plane not flaring at all. Since you can adjust the sink rate on final, perhaps you don’t need a flare with that wing.
I’m assuming this ‘pitch up’ or ‘flaring’ issue has been resolved. If so, would you mind sharing the solution? I’m having the same issue where the bird starts to flare between 5 to 10 ft AGL (1.5 to 3m) then decides to pitch up and glide up to 50-75 yards. Need a much more precise landing. Thanks.
