Hi.
I noticed that with the 3.2 version, if i connect a NMEA GPS (on serial 3 per exemple) with the param at “1” (autodetec) the autodection not working and i need to select the param at “5” (NMEA), in fact it’s the normal way.
But with the 2.51 version, the autodetection working normaly with a NMEA GPS, there was a modification in the new firmware?
I’m using the autodection with the NMEA GPS, because sometime i’m using the classical Ublox GPS and sometime an NMEA GPS, just by switching an mecanical switch without any param modification.
Regards,
