Hey guys, having a little Auto Pilot and Flight Controller blues. I was trying to set up my pixhawk cube and in the process I accidently snapped of the usc port, tor off the board pads and all. I’m looking for a replacement but can’t find the black cubes anywhere. On the Proficnc web site they no longer have it and suggest the orange cube, however when I read the reviews they aren’t good, I also considered the PX4 but the reviews on that board aren’t good either.
The fact that I have to power the rails on the Pixhawk’s is a bummer, I built step downs, and PMU’s for that but still had problems with signal to the OPTO’s and BEC’s (yes I only had 1 power wire from 1 esc connected, and the others where pulled out and no PMU connected on the BEC setup) , I almost had it when the accident happened. I’ve tried other Autopilots like the Naza lite v2, and even bought a K3A Pro, both bricked cause they don’t like windows 10 (set up and flashed per inrtuctions to the T, no missteps), that makes me hesitant about any of the DJI products, I was thinking about there AG line of autopilots, but that is quite the investment just to have them brick.
The Pixhawk cube I have set up on the JMRRC X1000 works great in ground testing, so I put together the the same set up for the JMRRC Hexi1650. These are AG’s I’m building, My goal is to build them with a raspberry Pi, and play with my own programs instead of GPS. I’ve went over everything, and wiring is good checked everything with the volt meter. I don’t know if I wan’t to buy the orange cube, does anyone have any suggestions on flight controllers that play nice with windows? and how about powering the rail with the pixhawk, it wouldn’t send signal to the esc’s till I went through, and disabled the checks, I got it to start working with 4 of the motors, even though I flashed, and programmed it as a hexi, but when I powered it down, and powered it up again, no signal to the esc’s, tested esc’s, and motors individually again but no startup for the esc’s. Signal runs fine through the receiver on throttle channel, esc’s chime and motor functions, I tested all motors. The multimeter picks up 5.082v across the rail, and I checked the signal wire connections. I’m using a DJI PMU to provide the 5v, the same on the X1000, works great on that rig. Any help would be appreciated, thank you for your time
