How fast are you flying the mission? Not sure if mission planner uses ground speed or airspeed. Wondering if auto speed isn’t fast enough to overcome wind speed!
Yes, the WPNAV_SPEED is ground speed so it should just lean over as best it can to overcome the windspeed. It is likely you’ll see “porpoising” if the vehicle reaches it’s maximum airspeed. AC3.6 will improve it’s performance at the limits.
@aamadeuss,
Perhaps, it’s really guess work without a log… there’s no way to know if it’s not trying hard enough or if it’s trying too hard and over reacting.
For the most part, there shouldn’t be any need to adjust the WPNAV accelerations… in general vehicle control issues come at the lower levels (angle or rate controllers). Anyway, like I said, it’s all guess work without a log…
