Hi good morning support .
I maidend my full size XUAV talon yesterday with no issues …
one observation I am requesting assistance with is the auto take off … I have configured the shake to wake parameters …all looks ok
I add a take off waypoint @50m alt @15 degrees climb …
The shake to wake functions are working ok when I launch the plane expecting it to climb out in a straight line , the plane banks to the left and turns approx. 90 degrees and then complete the auto take off mission…
I can confirm the following :
I armed the plane in the direction I wanted to take off
I selected Auto with the plane in the direction I wanted to take off
I am using the compass / GPS . No obvious issues … Compass calibration was successful
I have experienced this issue on a previous talon set up but thought it was due to the position of the plane heading prior to arming etc …
Any ideas what could be causing this ? The plane is equally balanced so the left side is not heavier …I have checked the MANUAL / FBWA & AUTO surface deflections …all ok . The Plane has been manually trimmed and I have Servo Auto trim active also…
Unfortunately I don’t have any Logs to upload. but I will get the logs on the next flight .
below is a link to the raw OSD footage on take off and flight … no other issues observed with the flight Controller all WP / FBWA and RTL good.
I’m using Makek H743 V2 With Arduplane 4.4.0
This is the flight you can see at the Hand launch. Immediately the plane rolls left then climbs in the intended direction on auto take off
Any support would be greatly appreciated
Thanks
Regards
NF
