Ive been having some strange issues with my quad which i wont get into here but, i thought id check my logs. im new to this and cant understand it yet. I wanted try the auto analyze button In Mission Planner (latest version (Jan2016 - cannot see where the name of the veriosn of mission planner is written) but when I press the button and load ANY of the recorded logs i get a window pop up saying - error NumpyDotNet.NpyCoreApi.
Then when i close that it is followed by " Bad input File" any Ideas? Is this a fault in the software? is it common?
I know i should learn how to read the logs but id really like this feature to give me a basic report on whats going on!
got the same problem with auto analysis in MP 1.3.35.
“NumpyDotNet.NpyCoreApi” and then " bad input file"
Have also tried to verify with the older MP version (1.3.33) to make sure it´s not a dataproblem with my logfiles but in there it works.
I also have exact same problem! Had no problems with this until I updated Mission Planner. Now I get the same “NumpyDotNet…” error when I try to use Auto Analyze. Any Ideas? Thanks…
Same problem here (version 1.13.35 build 1.5878.12941), but a workaround has been posted on GitHub (issue 1127) (which worked for me). It appears that it happens when NumpyDotNet.dll is loaded from a wrong location.
MP ver 1.3.37 bld 1.1.5917.13431
Pixhawk: APMCopter V3.3.3 (acf2e10c)
MP running on windows 7 environment
Downloaded logs, select “Auto Analysis” and navigate to folder where my log files are stored I get the following error: “Error Could not add reference to assembly mtrand.dll”. After receiving this error message I select OK, and I get the message “Bad input file”. Does not matter if I select log or .bin (bin is converted to log without an indicated error). I can’t upload my .bin file since this forum no longer seems to support uploading of bin!
Hey Michael, thanks for the reply. I did not mention this but this problem is on both my Laptop and Desktop computers (both MS win7). I did update both, no change. This time I uninstalled and reinstalled MP on both computers and that seems to have fixed the issue!!??
