i built an AT based on pixhak and 360 servo. i can connect to mission planner with the plane and tracker together but the problem is that the servo does’nt stop rotating… i can stop it only by clicking inside extended configuration and put it on neutral…
what can be the solution ?
i used a regular servo before and it worked fine but the range was limited so i wanted to change the servo to 360…
thank you
i tried to do it right now and the servo keep doing circles around itself… there is any solution for 360 tracking with the mission planner? maybe you know about other kind of servos that can rotate less than 360 but more than 180?
i configured the servo to continuously but it still rotating around itself…
i believe i’m missing something with the configuration.
MP must have a support for 360 trackers…
there is someone who did it before ?
thank you guys
