Hello, I made an octa Quad h frame drone and seemed to set it up correctly, but I’m still afraid to lift it since my previous drone crashed.Therefore, if anyone can check the parameter sheet, maybe I forgot to configure something important
I would also like to mention the features of the drone:
The remote control from the company SIYI MK 15 with a spring-loaded throttle (by default it is located in the center)
The drone turned out to be quite heavy 7 kg (since it was assembled from improvised materials)
3.there are 2 batteries on board for 6S 7000mah connected in parallel and I couldn’t set up the battery monitor
The last time I started it, the initial mode was Stabilized and since the gas stick was spring-loaded, I couldn’t get it to the bottom and the drone soared into the air, after which I panicked and turned it off.In this regard, the question is whether it is possible to make it rise smoothly
I would really appreciate it if you could help
copters H frame.param (17.4 KB)
