i hope seniors here can assist and check my log file as i’ve spotted a test PM fail : 25 slow loop lines found, max 9.98% on line 25339.
however my build is as follows;
Tarot 650 frame weight : 450g
FC: Pixhawk autopilot weight : 63g
3DR radio telemetry : 15.6g
3DR GPS with mast weight : 16.8g
SunnySky V3508-29 KV380 Brushless Motor weight : 107g x 4 = 428g
Afro Slim 20Amp esc weight :13.7g x 4 = 54.8g
HK CF Prop 17X5.5. weight: 25.0g x 4 =100g
Battery: Lipo, Zolta 35C 4S1P 5200mAh weight : 483g
Tarot T-2D Brushless Camera Mount Gimbal weight : 540g
Additional battery for FPV and Gimbal : Voltron Li-Polymer Battery 1050mAh/35C 11.1V 3Cells Weight: 97grams
Boscam FPV 5.8G 200mW AV Wireless Transmitter TS351 weight : 25g
Total weight : 2273.2g
Log File C:/Users/user/AppData/Local/Temp/tmp51A5.tmp.log
Size (kb) 4584.40625
No of lines 72621
Duration 0:04:23
Vehicletype ArduCopter
Firmware Version V3.2.1
Firmware Hash 36b405fb
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = GOOD - [+] Autotune 6117-67884
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (15.98%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = WARN - Min satellites: 6, Max HDop: 4.65
Test: IMU Mismatch = GOOD - (Mismatch: 0.13, WARN: 0.75, FAIL: 1.50)
Test: Parameters = GOOD -
Test: PM = FAIL - 25 slow loop lines found, max 9.98% on line 25339
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = GOOD -
