I was setting up filters for a helicopter and had a question that prompted me to write this post.
Currently, there is a notch filter at 35Hz and a 20Hz LPF on the gyro as shown in the photo below.
If the gyro LPF is 20Hz, there is no problem, but if the LPF is increased to 60-80Hz, does the second notch filter need to be applied at 131Hz accordingly?
Also, since a low LPF causes delay, I want to increase the gyro LPF value to 60-80 Hz for better control. However, in my search, it seems that most people use a gyro LPF of 10-20 Hz.
I’m also wondering if using the current 20 Hz frequency of the gyro LPF will not interfere with the controller’s internal loop.
The flight log is attached at the link below.
flight log 1
flight log 2
Thanks for taking the time to read my post
