Hi everyone
whenarspd_type=0- Why the ARDSP_USE=1, didn’t show up?
I would like to use it as reported here (arduplane):
ARSPD_USE determines if the airspeed estimate is used in other ArduPlane functions besides speed scaling. If no airspeed sensor is present and ARSPD_USE =1, then the estimated airspeed will be used as if was obtained via an accurate airspeed sensor.
Warning
using the estimated airspeed for speed controlled modes by enabling ARSPD_USE without an airspeed sensor can result in erratic, or even dangerous, operation since the estimate can be wrong in situations like automatic takeoffs into a strong headwind, or when flying into the wind for an extended period without making any turns (which updates the wind speed estimate and therefore the estimated airspeed).
