I saw that my quad X arm also without GPS 3D fix.
Why this ?
i have setup to check 3D fix before arm.
You should still have “All” selected for Arming Checks.
You can arm in Stabilise or AltHold mode (or any manual mode) without a GPS 3D Fix provided you dont have the Fence enabled.
If you need to arm in Loiter or any GPS assisted mode, or have Fence enabled, you need a GPS 3D fix and Home can be set before arming.
@xfacta thanks for answer.
I arm in Stabilize mode and i dont have Fence enabled becouse i cannot put Enable becouse the field is disabled.
Today i try to put All in Arm Check.
Always have ARMING_CHECK,1
or “All”
The arming check warns you about components that might have a fault.
Fence is a separate parameter, look in the Full Parameter List.
If you enable the Fence you will NOT be able to arm in any mode until there is a good GPS 3D fix and Home can be set.
These are the main parameters:
FENCE_ENABLE,1
FENCE_ALT_MAX,120
FENCE_RADIUS,500
Check you local laws for what is allowed
I saw in another discussion you are using an ESP32 and some options are not compiled in.
I would saw you would have to compile from source to ensure the options you need are included. There arent any pre-built firmware downloads for this board.
When I looked through the pull requests for ESP32 I would say this board is experimental for Ardupilot use.
@xfacta yes Shawn. My ESP32 work fine but not GPS.
I think that i must add Geo Fence option for have it.
thanks much for your infos.
Adding the Fence wont make the GPS work.
You might need to check your wiring
It also works without, but it works better, more reliably and safer with it!
Just do what @xfacta says.
