I’m making a rover and I need to use GPS RTK.
In France we have a free RTK network (Centipède), so to acces them from the rover I need to get mobile connexion, such as 4G connexion.
I’m searching from several days the righ architecture, but doesn’t find a architecutre WITHOUT Mission Planer / Qgroundcontrol for connecting to NTRIP caster.
My goal is only rover + pixhawk + F9P + 4G connexion, no connexion via Telemtry to Mission Planer during Mission.
I would like to make this architecture : F9P > PixHawk > RPI > 4G Connexion
But I dosen’t find how I can send the RCTM3 frame from RPI to PixHawk.
I think mavproxy is overkill if used only for RTCM and sometimes, at least in my case, it has been very very unstable and shutting down RTCM for no reason.
Been using str2str for nearly 2 years now with no probs at all, very reliable.
Figured MAVProxy might be a readymade solution that is well documented. I’ve used ser2net on a Raspberry Pi as a much lighter weight solution with a great deal of success, as well.
Serial RTCM3 → R Pi → ser2net → network connection → companion or GCS computer → autopilot
Perhaps I’m thinking a bit too complex, though. With an onboard companion and a cell connection, it could connect directly to the NTRIP server and then output over UART to the autopilot.
Ah ok. I was talking about str2str, part of rtklib. Can connect to a cors and stream connection out. So it is ideal for 4g connected raspberry.
Really takes 5 minutes to setup on a raspberry.
(i am about half way trough your lua video tutorial. Really nice, thanks).
just for clarification : in all case, the computing of the RTCM3 frame is made IN the GPS F9P module ?
(it’s not my use case, but just to clarify : So when we send RTCM via Telemetry, pixhawk just transfer the frame to the F9P and then F9P return corrected position ?)
