Using Dronekit(python) for Rover:
command “mavutil.mavlink.MAV_FRAME_BODY_OFFSET_NED” doesn’t work with Rover? any other command that can send velocity movement to Rover?
I’ve met the same problem,have you got the solution? Thank you.
