I am using a PixHawk4 connected to a Roboclaw 2x45A. I have set the Pilot_Steer_Type=1 for Skid Steer Enable, connected the PixHawk (IO PWM Out PINS 2,4,10) to the Roboclaw PINS (S1 I/O,S2 I/O, GND). I also have set SERVO1_FUNCTION=73 and SERVO2_FUNCTION=74. I have the RoboClaw set to RC input and the MCU enabled to remove the AutoCalibration
When I go to test the motors using the QGroundControl I can get movement on both Motors Individually. When I try to use MavProxy Commandline function “rc all 1400” I see movement in my motors. However, when I try to isolate the individual motors I cannot get any movement and the only command that works “rc 3 1400” moves both motors. Am I doing something wrong here?
All I am trying to do is be able to control the individuals motors to move. Any assistance would be greatly appreciated.
Pilot steer type 1 is most certainly wrong, except if you have a TX with no sticky throttle.
The rest of your description is a little hard to understand. You say you use Pixhawk servo pins 2, 4 and 10. Why three pins? Where are they connected to? Why pin 2 and 4, if servo out 1 and servo out 2 are setup for skid steering?
Thanks for the response.
Why would the steering type be incorrect if we are trying to use it as a skid steer?
Also on the IO PWM OUT port of the pixhawk 4 the pin out is that pin 1 is VDD servo, pin 2 is PWM 1 OUT, pin 3 is PWM OUT and so on and and pin 10 is ground so effectively we are connecting PWM 1 to S1 on the Roboclaw PWM 3 to S2 and GND to GND.
Does that make more sense? In my previous response it should have been SERVO1 and SERVO3 I apologize for the mistake
Ah, ok. I am not familiar with the Pixhawk 4, so I thought you were talking about PWM signal pins. It does not matter where you connect the outputs, as long as connection and configuration match. Connecting to servo output 1 and servo output 3 is no longer required.
Skid steering is activated by selecting throttle left and throttle right as servo outputs. Pilot steer type is a mix of selecting a input type (1, two stick input, like in a real tank and reversing behaviour does not apply) and reversing behaviour for single stick input (2, 3)
