If the drone is not connected I’m not able to add fixed wing waypoints in the plan tab such as loiter to alt or do land start, is there anything that I’m missing in the configuration tab? That wasn’t a problem in previous versions.
Thanks,
Jordi
Yep, by default it loads config for copter. Just start Plane in simulator, once it connected settings are changed for Plane, you can disconnect, it will keep that way till next restart of MP.
But there is another way. If you save this as settoap.cs and put into C:\Program Files (x86)\Mission Planner\plugins directory (or wherever is your MP installed) it sets the default to Plane at start.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using MissionPlanner.Utilities;
using System.IO;
using System.Windows.Forms;
using System.Diagnostics;
using MissionPlanner;
using MissionPlanner.ArduPilot;
namespace Shortcuts
public class Plugin : MissionPlanner.Plugin.Plugin
public override string Name
get { return "Set default to ArduPlane"; }
public override string Version
get { return "1.0"; }
public override string Author
get { return "EOSBandi"; }
public override bool Init()
return true;
public override bool Loaded()
Host.cs.firmware = MissionPlanner.ArduPilot.Firmwares.ArduPlane;
return true;
public override bool Loop()
return true;
public override bool Exit()
return true;
Thank you very much, the settoap plugin works perfect. First option didn’t work, it seems it keeps setting default to copter both after using simulator and connecting to the drone.
Thanks!
Jordi
