I’m trying to build ArduPlane locally so I can get SITL up and running. So far I’ve cloned the repo, configured waf, and built waf plane. I’m getting two issues.
When I run sim_vehicle.py --map --console -f plane compilation succeeds, but I get
[Run MavProxy] An exception has occurred with command: ‘mavproxy.py --map --console --out 127.0.0.1:14550 --out 127.0.0.1:14551 --master tcp:127.0.0.1:5760 --sitl 127.0.0.1:5501’
[Errno 2] No such file or directory
mavproxy was installed successfully via pip install mavproxy
If I add --osd, I don’t even get a successful build. I see
[147/669] Compiling libraries/AP_Gripper/AP_Gripper_EPM.cpp
In file included from …/…/libraries/AP_Filesystem/AP_Filesystem_ROMFS.cpp:21:0:
…/…/libraries/AP_Math/AP_Math.h: In instantiation of ‘decltype (((one < two) ? one : two)) MIN(const A&, const B&) [with A = unsigned int; B = int; decltype (((one < two) ? one : two)) = unsigned int]’:
…/…/libraries/AP_Filesystem/AP_Filesystem_ROMFS.cpp:100:49: required from here
…/…/libraries/AP_Math/AP_Math.h:209:16: error: comparison between signed and unsigned integer expressions [-Werror=sign-compare]
return one < two ? one : two; ^
compilation terminated due to -Wfatal-errors.
cc1plus: some warnings being treated as errors
Waf: Leaving directory `/home/noah/code/ardupilot/build/sitl’
Build failed
-> task in ‘objs/AP_Filesystem’ failed (exit status 1):
{task 140387936722512: cxx AP_Filesystem_ROMFS.cpp -> AP_Filesystem_ROMFS.cpp.0.o}
(run with -v to display more information)
SIM_VEHICLE: Build failed
Looks like people haven’t had this issue on 18.04 in the past. Not sure what I’m doing wrong. Is there a earlier more stable tag I should check out on git?
No, but when I try with that configuration command, it then fails to build with ./waf plane, same error. Are you on 18.04, latest ardupilot from master?
Thank you, I didn’t do the --user flag so I guess that was important. I got other paths from ardupilot automatically added to my .profile so it’s weird that it missed mavproxy.
The sign bug got fixed over in the git repo so I’m all up and running!
Hello, I don’t know exactly how to use the forum sorry if I wrote it wrong. I’m getting this error when installing ardupilot on 18.04 ubuntu.
SIM_VEHICLE: Start
SIM_VEHICLE: Killing tasks
SIM_VEHICLE: Starting up at SITL location
SIM_VEHICLE: WAF build
SIM_VEHICLE: Configure waf
SIM_VEHICLE: “/home/droneseverler/ardupilot/modules/waf/waf-light” “configure” “–board” “sitl”
Setting top to : /home/droneseverler/ardupilot
Setting out to : /home/droneseverler/ardupilot/build
Autoconfiguration : enabled
Checking for program ‘python’ : /usr/bin/python
Checking for python version >= 3.6.9 : 2.7.17
The python version is too old, expecting (3, 6, 9)
(complete log in /home/droneseverler/ardupilot/build/config.log)
SIM_VEHICLE: (Configure waf) exited with code 256
have you solved the problem?
i have same problem, while compiling it’s failed.
this error appear while im running sim_vehicle.py --map --console in directory ardupilo/ArduCopter
using ubuntu 18, jetson nano. Thx
[ 923/1181] Compiling libraries/AP_Motors/AP_MotorsMatrix.cpp
…/…/libraries/AP_Logger/AP_Logger_Backend.cpp: In member function ‘bool AP_Logger_Backend::Write_VER()’:
…/…/libraries/AP_Logger/AP_Logger_Backend.cpp:578:5: sorry, unimplemented: non-trivial designated initializers not supported
Waf: Leaving directory `/home/nano/ardupilot/build/sitl’
Build failed
→ task in ‘objs/AP_Logger/ArduCopter’ failed (exit status 1):
{task 547944786184: cxx AP_Logger_Backend.cpp → AP_Logger_Backend.cpp.3.o}
