I was flying a small Piper Cub fitted with an APM 2.6 , arduplane and a Graupner radio. To be able to use new software release, I switched to a PixHawk controler.
I decided to connect the Pixhawk and the GR 16 receiver with the DSM interface and the setting SUMDOF08 of the receiver.
But the pixhawk stays in failsafe with these settings. I did some check with a GR12L and it was ok.
After some investigations, I found that on power on, the GR 16 receiver was sending frame with failsafe flag on (=> frame are starting with A8 81 and not A8 01 for a normal frame) up to the connection establishment with the transmitter. After that if the connection is lost, sumd frame are not transmitted.
This is not the case on GR12L : there is not sumd frame transmitted between power on an transmitter connection establishment.
After digging into the code I found that sumd frame with falisafe bit on ( beginning with A8 81) was not recognized as sumd frame (file sumd.c). I think in this case the algorithm concludes that the sumd protocol is not used and lock on another one : this is the reason of my problem.
After modification of sumd.c , sumd.h and controls.c , it is possible to :
recognize and decode sumd frame with failsafe bit on
set or clear the pixhawk failsafe status with this information.
The issue seems to be solved.
I will try to post detailed modification in a next message.
I have some difficulties to extract with git the modification I have done.
=> I can propose unix diff of modifications.
Is there a probability to have them embedded in the master ?
sumd.h and sumd.c are from the ardupilot/modules/PX4Firmware/src/lib/rc directory
controls.c is from the ardupilot/modules/PX4Firmware/src/modules/px4iofirmware directory
diff original/sumd.h modifie/sumd.h
96a97
@param failsafe pointer to a boolean where the decoded failsafe flag is written back to
105c106
< uint16_t *channels, uint16_t max_chan_count);
Hi Sandre Benoit, I have started to imlement a Pixhawk 2.1 on a RC plane and I do also have Graupner RC equipment and a GR-12L receiver.
Do you know if I can “just” use this receiver and connect it with RC IN on the Pixhawk? Or is the Graupner GR-12L signal not usable for a Pixhawk? And if so what do I need to change?
Thank you very much in advance for every response - of course from other users as well!!!
Alexander
Hi Benoit, I thank you very much for your responses. Unfortunately, the Pixhawk 2.1 has no DSM socket (in comparison to Pixhawk 4 for example).
I checked that the GR-12L receiver gives a PPM signal on channel 6 but no chance to receive anything during calibration of the radio controls. Can you imagine any solution?
Best regards,
Alexander
