The UAV Log viewer plot.ardupilot.org doesn’t seem to be able to handle logs created with 4.3 or higher (tried with 4.3.0 and 4.3.1) when running on Safari 16.0 and Google Chrome 106.0.5249.119 and Microsoft Edge Version 107.0.1418.24 (Official build) (64-bit). I get the error:
An error occurred while rendering. Rendering has stopped.
I have tried older logs that worked in the past and they load fine. Specifically I tried 4.2.3 and it works.
This is an example of a log that throws the error.
Looks like you accelerate from 5 m/s (headwind, likely) to 15-17 m/s on takeoff and then 14-15 m/s just before landing in what appears to be a 6 m/s headwind.
The peak in the early part of the flight is 22.83 m/s.
Thanks @Yuri_Rage , if it’s not too much to ask could you also show altitude, so I can see what the speed is when it leaves the ground and lands? Oh - I have a LIDAR, so if you know the metric for LIDAR height that would be even better.
I’ve just put wheels back on the Binary, so what I am trying to do is figure out my takeoff and landings speeds so I can set the parameters for auto takeoff/landing which I really want to try.
[FYI - like mavexplorer, Mission Planner has never been able to load/view logs for me on my Mac - hence I usually use plot.ardupilot.org]
