ArduPilot EU Dev Call 2025-05-07
Attendees (unique): 12
UTC0707
Andy: Apparently NODMA is now correctly marked.
  • And only one IMU is mentioned in the README.
  • So probably all comments are fixed.
Merged!
UTC0710
Approved
UTC0713
Andrew: I couldn’t get master to connect to BLHeli, but with this PR I managed to once.
  • Betaflight manages every time.
Andy: Are these AM32 ESCs?
A: Yes, they are. You can still flash non-CAN firmware on them.
Andy: AM32 in general doesn’t work with any of our releases. BLHeli generally does. BlueJay somewhere in the middle.
A: I noticed the last (stop) bit of an 8N1 packet from AM32 was half-width. I fixed it but it broke compatibility with many config tools. The issue seems to be that CPUs bit-bang the serial but they don’t have time to do the next thing, if they linger the full duration on that last bit.
  • It would be nice if the flight firmwares weren’t so pressing on the ESC to send/receive the next byte.
  • Do we have enough threading priority?
Andy: We probably do.
A: What if we shut down most other threads during passthrough?
Andy: Perhaps it will help with timings.
UTC0729
< Discussion on param ftp internals, to address an occasional issue on param ftp load >
UTC0737
Andy: I’m still getting an instant watchdog.
  • It’s most likely a race condition.
A: We need Randy for this, unfortunately.
UTC0738
Merged!
UTC0743
We still can’t use clang in our everyday builds.
< Discussion on ways to lock down parameters against accidental changes. >
