ArduPilot EU Dev Call 2025-04-09
Attendees (unique): 16
UTC0703
Andy: Overflows Pixhawk1, so it can’t be immediately brought into 4.6.
Andrew: We’ll need to ifdef it or scrounge up some space.
Peter: Remove DShot-on-IOMCU support from Pixhawk1 to make space?
Andr: Okay, then let’s have a PR dropping the IOMCU-DShot in Pixhawk1 <1M flash and then we bring this one in.
  • Let’s drop ICE and EFI on minimized feature builds. That’s going to affect the least number of people.
UTC0709
Andr: Didn’t test yet, sorry.
UTC0710
Andr: It would be better if we pulled up to 5V, for better signal integrity.
Andy: I flew with internal pullup to 3V3 and external to 5V and it still flew fine.
  • People already have issues without it.
    Andr: TBS needs to test it.
UTC0712
Andy: We disabled this one by accident.
  • The old config affects the pin definitions.
Merged!
UTC0714
Andy: There’s a new Lua applet for this.
Andr: WikiNeeded.
Merged!
UTC0717
Peter: Depends on a PR on the MAVLink repo.
Andr: That PR needs to match the upstream MAVLink PR.
  • The ArduPilot/ardupilot PR itself looks alright.
UTC0724
Ankur: It is meant to integrate autogenerated code from Simulink with ArduPilot
  • We would like to be able to write apps not only for controllers, but also for any kind of code (sensors, read measurements, etc).
    Sid: They are asking for their own library within AP, which they can maintain.
    Andr: How is CI going to be working on our end?
    Sid: They have hand-written a “dummy” binary that has the same API as Simulink and will be probing/using the code under test.
    Andr: Is this meant to be for experiments only or for production as well?
    Ankur: From our PX4 experience, people don’t use it for production.
    Andr: What is the license of the Simulink-genereted code?
    Ankur: It’s your code, you do what you want with it. I’ll double check and get an official response.
    Sid: I was told the same thing.
    Andr: How about the other vehicles? This is Copter only.
    Ankur: There are more PRs to come.
    Andr: Why are there so many thin wrappers around AP’s methods?
    Arun: We can better prepare for abstractions towards other vehicles.
    Andr: I don’t think abstracting to othe vehicles will be possible, even with this interface.
    Sid: Is the naming the reason you need those additional wrappers?
    Ankur: The Simulink blocks invoke the glue code, and that was a cleaner implementation.
    Andr: You could just as well do this by invoking the ArduPilot libraries.
  • But more to the point, we don’t like having APIs specific for particular vendors.
  • It’s also impossible with this implementation to disable the custom controller. Both controllers will be running simulteneously, even logging.
    Ankur: Some of our clients want to write controllers that complement the existing ones, not override them.
    Andr: If you want to augment the standard controller, you could call it purposely from your own controller.
  • Also, your current implementation isn’t thread-safe, w.r.t. Andy’s fast-task controllers. It will compete for control on the ouptut pins.
  • The course of action is to get Pete Hall involved, he is the one who knows our custom controller mechanics best.
    Sid: I’ll make this call happen.
    Andr: Ideally we’d prefer if you could fit on the existing custom controller, or even extend it. But at the least we want a solution that can be test-flown safely.
UTC0804
Merged! Blame Peter for all future bugs :wink:
UTC0807
UTC0808
Merged!
Peter: Are we happy to install Docker in our Custom Build Server?
Andr: Yes, go ahead. Let’s make sure Shiv has the right user rights.
UTC0812
