ArduPilot EU Dev call 2024-10-16
Attendees (max): 9
UTC0757
Merged!
UTC0759
Andrew: is_zero(param:get()) should work
George: Ok, I’ll try again.
UTC0802
Merged!
UTC0803
Merged!
UTC0805
A: can_imu_update() could use a small sleep.
Sid: Do but we don’t do that on the vehicles?
A: But the main thread here doesn’t do anything more important. So this could turn into a hard-spinning thread.
S: I’ll add 100us, it’s fine.
A: There’s one change in the bootloader file. Let’s make sure that only the CubeNode bootloader gets affected.
  • I’m not sure about the changes in the .h files. Peter should check them.
UTC0902
Peter: Will need some cleanup on the build server directories.
  • I’m using Tools/scripts/size_compare_brancyes.py to compare the binary size changes.
  • No changes on the vehicle bootloader binaries.
  • Left change requests.
UTC0817
S: This fixes things on my system. Build doesn’t work right now.
A: Doesn’t look right.
  • You could try the --ignore-options flag to get the error to go away.
S: But it doesn’t fix my issue.
A: You could try to strace the error and find out what the actual problem is.
UTC0826
MergedOnCIPass.
UTC0827
A: Needs some changes to ensure that the heap does not overflow.
UTC0840
A: This will allow proper support for external AHRSs, because it will allow for EKF lane switches, in case of solution degradation.
  • Needs a reviewer.
UTC0845
A: Will need a reviewer.
  • Then we’ll need a lot of testing to make sure it doesn’t break in action.
  • The idea is for this to eventually replace DCM.
UTC0848
Randy: If Pete wants to merge this, feel free.
UTC0852
A: It will have to wait for 4.7, unfortunately.
Pete: That’s fine.
UTC0929
MergeOnCIPass
UTC0855
A: This is pretty urgent, leads to a large climb.
  • Needs autotests before it gets merged.
There will be NO Dev Call on Tuesday!
