andyp1per
(Andyp1per)
1
ArduPilot EU Dev Call 2023-02-22
Attendee count (max): 10
- Fast sampling for ICM45686
- Tested by Andy
- Merged!
- AP_Scripting: DJIRS2 gimbal driver upside down support
- Merged!
- AP_Camera: frontend/backend split and support for 2 cameras
- Separates out camera types into different backends
- Details in PR
- Single camera type now
- Mavlink no longer always sends messages to the back end
- Looks good
- Needs some scripting bindings
- Needs testing on real hardware - tridge to fly
- Add image number to camera message
- Mamba F405 2022 VTX Power
- Will go in 4.3
- Merged!
- AP_PiccoloCAN: Fix ESC voltage and current telem scaling
- Merged!
- Additional IMUs support
- Motivation is to allow users to test additional IMUs
- New Cubes can have up to 5 IMUs
- Maybe should go into 4.5
- Parameter conversion takes up space
- Needs testing - tridge to fly on weekend
- Needs testing in SITL
- AP_HAL_ChibiOS: Fix half-duplex serial on L431 periph nodes
- MergeOnCIPass
- Jump Tags: add scripting hooks and examples
- Will wait for precursor PR to be merged
- Add and use a “bool read(c)” method to AP_HAL
- Tridge not convinced this is the right approach
- Saves some flash
- Plane: move mode training and stabilise to mode files.
- Tridge to do some testing and flying
UTC0827 AP_AccelCal: correct machine state update by peterbarker · Pull Request #18844 · ArduPilot/ardupilot · GitHub
- AP_AccelCal: correct machine state update
- Correct IMU consistency checks
- Fixes a bug that Peter introduced
- Bug is also in 4.3
- MergeOnCIPass
- AP_Scripting: luacheck: check globals
- More lua checking is good lua checking!
- Merged!
- AP_Motors: add throttle output logging
- Isn’t this already logged in CTUN and RATE?
- Add defines for remaining compasses
- Merged!
- Fix flash overflow building DrotekP3Pro bootloader
- Merged!
UTC0842 - Close
