Attendee count (max): 10
UTC 0702 - Cleanup Dronecan generate build step by bugobliterator · Pull Request #22044 · ArduPilot/ardupilot · GitHub
- Discussion of changes to CAN bootloader
- Uses DroneCAN
- Increases flash usage by 200 bytes on CAN devices
- Needs testing
UTC0714 - DroneCAN Serial Tunnel by bugobliterator · Pull Request #21942 · ArduPilot/ardupilot · GitHub
- DroneCAN serial tunnel
- Some discussion of the protocol inside the tunnel
- Virtual UART has to receive before it can send
- Some discussion about whether the design is correct
- Tridge believes that we need IDs to represent endpoints in order to disambiguate
- Need the node to be able to specify what it’s ID is
UTC0747 - Add turtle mode safety features by andyp1per · Pull Request #22016 · ArduPilot/ardupilot · GitHub
Turtle mode safety features
Some discussion about old code dorking with failsafe parameters
Just needs the spoolup block moved below the arming check
UTC0757 - GCS_MAVLink: scale number of FTP responses based on mavlink stream slowdowns by peterbarker · Pull Request #22062 · ArduPilot/ardupilot · GitHub
Increase number of ftp replies in mavlink when slowdown occurs
Drive-by proposal from Peter to address parameter download over slow links
Tridge agrees we should try this
Needs testing
UTC0803 - GCS_MAVLink: correct potential uint underflow n stream slowdown by peterbarker · Pull Request #22060 · ArduPilot/ardupilot · GitHub
- Uint underflow in stream slowdown
- Potential bug
- Just needs testing
- MergeOnCIPass
UTC0805 - Simplify definition of HAL_WITH_DSP by peterbarker · Pull Request #21936 · ArduPilot/ardupilot · GitHub
Mean users don’t see HAL_WITH_DSP
Not passing CI - needs some rework
UTC0807 - AP_InertialSensor: add fast reset for ICM20602 instead of full reset on bad temp sample by bugobliterator · Pull Request #22035 · ArduPilot/ardupilot · GitHub
Fast reset for ICM20602
Needs testing by MDB
Debug message can be simplified
Looping over mavlink channels can have unintended consequences
Tridge would like ifdef to restrict to certain boards on 4.3
UTC0821 - Add support for ICM45686 IMU by bugobliterator · Pull Request #22028 · ArduPilot/ardupilot · GitHub
- Support for new ICM45686
- Andy had some questions about support better filtering and different backend rates support
- No datasheet yet and chip not shipping so can come later
- Some discussion over internal and external i2c probing, tridge doesn’t like cube specific changes
- Some discussion around Invensense3 size - but chip availability means we need to support all
- Need a size check for Invensense3
