Hello Copter Simulation forum,
I would like to develop an application controlling an Arducopter. In conjunction with the physical system, I’d like to use Arducopter SITL to help me make more total flights and crash the physical system less. In the course of development, I expect the application controller wall clock runtime to vary in computational expense from the very short to the very long.
In the detail below, I have tested some variations of stock autotest tests. The variations seem to show that adding time.sleep changes simulation results. I was hoping for my tests, simulation results would be invariant of time.sleep.
Two questions:
- Can Arducopter SITL be driven to produce the same behavior from run to run regardless of how much wall clock time passes?
- If yes, then what is the best example code or documentation illustrating the required APIs?
Thanks in advance,
Jeff Henrikson
Detail
Ardupilot version:
ardupilot source on github, master branch, commit 4b24a6 on Mon Jul 9 22:26:49 2018
Scenario
My hypothesis for how I will test my application controller with SITL is to write tests that connect to a SITL process like this one over TCP port 5760:
../build/sitl/bin/arducopter --home -35,149,584,270 --model quad
In order to understand time semantics of Arducopter SITL, I have started by experimenting with this file:
Tools/autotest/arducopter.py
I can run the file as follows, and get changes to tests to respond:
../Tools/autotest/autotest.py --frame=quad build.ArduCopter fly.ArduCopter
I have run the wait_altitude call here in three different variations:
class AutoTestCopter(AutoTest):
def takeoff(self, alt_min=30, takeoff_throttle=1700, arm=False):
"""Takeoff get to 30m altitude."""
if alt < alt_min:
self.wait_altitude(alt_min,
(alt_min + 5),
timeout=30,
relative=True)
Variations
Variation 1
Make the 30 second timeout explicit instead of a default argument.
Expected result: Altitude OK.
Actual result: Altitude OK.
if alt < alt_min:
(alt_min + 5),
timeout=30,
relative=True)
AUTOTEST: Got mode STABILIZE
rc 3 1700
rc 3 1700
STABILIZE> AUTOTEST: Waiting for altitude between 10 and 15
AUTOTEST: Wait Altitude: Cur:0, min_alt:10, climb_rate: 0
AUTOTEST: Wait Altitude: Cur:1, min_alt:10, climb_rate: 0
AUTOTEST: Wait Altitude: Cur:2, min_alt:10, climb_rate: 0
AUTOTEST: Wait Altitude: Cur:3, min_alt:10, climb_rate: 0
APM: EKF2 IMU0 in-flight yaw alignment complete
APM: EKF2 IMU1 in-flight yaw alignment complete
AUTOTEST: Wait Altitude: Cur:4, min_alt:10, climb_rate: 0
AUTOTEST: Wait Altitude: Cur:5, min_alt:10, climb_rate: 0
AUTOTEST: Wait Altitude: Cur:6, min_alt:10, climb_rate: 0
AUTOTEST: Wait Altitude: Cur:7, min_alt:10, climb_rate: 0
AUTOTEST: Wait Altitude: Cur:8, min_alt:10, climb_rate: 0
AUTOTEST: Wait Altitude: Cur:9, min_alt:10, climb_rate: 0
height 10
AUTOTEST: Wait Altitude: Cur:10, min_alt:10, climb_rate: 1
AUTOTEST: Altitude OK
rc 3 1500
rc 3 1500
STABILIZE> AUTOTEST: TAKEOFF COMPLETE
Variation 2
Change the timeout to be 1 second.
Expected result: Failed to attain altitude range.
Actual result: Failed to attain altitude range.
if alt < alt_min:
(alt_min + 5),
timeout=1,
relative=True)
AUTOTEST: Failed to attain altitude range
AUTOTEST: FAILED: "Takeoff to test fly Square": WaitAltitudeTimout()
Variation 3
Change the timeout to be 1 second, and precede with a 30 second time.sleep.
Expected result: Failed to attain altitude range, same as Variation 2.
Actual result: Failed to attain altitude range, but simulated height is up to 1020.
#does wall clock sleep allow it to pass?
if alt < alt_min:
time.sleep(30)
(alt_min + 5),
timeout=1,
relative=True)
AUTOTEST: Wait Altitude: Cur:1027, min_alt:-5, climb_rate: 0
AUTOTEST: Wait Altitude: Cur:1026, min_alt:-5, climb_rate: 0
AUTOTEST: FAILED: "Fly copter mission": WaitAltitudeTimout()
height 1020
height 1010
height 1000
height 990
height 980
height 970
height 960
Flight battery 30 percent
height 950
height 940
