Hello all! I would appreciate some help diagnosing strange behavior.
Context: I had crashed a quad (my fault) and did some stack overhaul. Added a Skystars H7 HD flight controller and ESC and changed the RC to @olliw42 's excellent mLRS system.
I’m experiencing an issue I can’t seem to fix: the quad pitches forward when I increase throttle and will eventually flip if I don’t disarm. Before it flips, the quad does not respond to my stick input as expected (eg: yaw doesn’t produce a yaw and so on and so forth)
RC is a Radiomaster Boxer with channel order AETR, mLRS RX channel output is AETR, and my RC channel order in AP is AETR
I am flying X Frame, Betaflight X motor order and the props direction and motor spin order are good
I’m only trying to takeoff and confirm the basic tune in order to go into my autotune steps.
I believe that this is a channel order problem, but considering I set everything to AETR and the Radio Calibration tab of Mission Planner shows the desired outputs, I’m not sure what I’m missing.
Prior to posting I confirmed my frame layout params, conducted a motor test, and also checked the artificial horizon in Mission Planner to validate AHRS_ORIENTATION. All of these params as well as the ESC settings look good.
That’s why I believe something with mLRS channel order is involved. Hoping it’s something else I’ve overlooked!
