Hi guys
I need precise control of near surface altitude in GUIDED mode and not performing a landing, GPS and barometer can’t hold its alt so I turned for rangefinder. After I correctly configured the rangefinder, it holds its alt perfectly when using GUIDED mode with no control inputs. I tried this by placing a box under my copter when its flying. However, when I try using simple_goto() function, it can’t hold its alt and I assume its using barometer data because when there’s no wind, it holds its alt, but when there’s strong wind, it just changes altitude.
I’m using a PixHawk 2.4.8 with arducopter 4.3.7 stable, I don’t want to use RTK.
Is there any way to configure rangefinder as primary altitude source in GUIDED mode? My copter operates at around 5m above ground so rangefinder is reliable.
Hi! Did you solve the problem. I have this problem too.
Thanks for your answer.
