Like the title says. Flashed holybro X6 with the latest FW and got this error message instantly.
Tried different versions, tried to manually set the brd_type, nothing made a difference.
Don’t ever do that. Try using QGC and choose Ardupilot Stable version.
I only did it using qgc. I even tried mission planner but result is the same
When using MP did you download the Stable .apj file from the repository and use “load custom firmware” to flash it?
I tried both, choosing it from the list and downloading stable and loading custom firmware.
There was a change merged into Master recently for the 6X, try that. Download the .apj from the “Latest” repository. Unless you tried that already.
Tried that, but still the same issue.
I tried even the latest DEV version, but still the same issue. Can it be something regarding the baseplate?
I have had issues with failed updates on the 6X, try holding down the safety switch when powering on to see if that makes a difference
I do not have the safety button anywhere. The baseboard has been designed by us. I ordered a regular baseboard to see if it makes any difference.
