Hello everyone, my name is Burak. I am trying to simulate with airsim on windows platform. I have installed all the requirements. As seen in the first image, ardupilot sitl works successfully and I can connect with the mission planner. I can do guided control by connecting with the dronekit library. In addition, Airsim application works successfully when the setting.json file is not changed as seen in the image.
However
When I change the parameters in the setting.json file for the Airsim program as in the documentation, the screen locks up and the program becomes inoperable on the task manager.
Also
When I run the sim_vehicle.py file by adding the -f airsim-copter parameter, I am not getting any data and I am encountering the errors in the figure.
Could you help with this?
