I’m running a Python 3.10 system on a Jetson Orin Nano, using dronekit installed from this GH repo and Ardupilot 4.4.1 on a Pixhawk 6C. The drone itself has good GPS lock, optical flow, and rangefinder for altitude information. The following code constructs a mavlink message for set_position_target_local_ned
using dronekit, which I then send simply using self.vehicle.send_mavlink(self.setpoint_msg)
once per second. But for some reason, the UAV ignores all the setpoint messages, regardless of what kind of bit mask I use.
I can take off and land autonomously, but for all messages that I send, the drone just hovers in place doing nothing.
Any help will be very appreciated! Thanks in advance.
def update_velocity_setpoint(self, frdy: np.ndarray) -> None:
"""Sets a new velocity setpoint.
Args:
frdy (np.ndarray): frdy
setpoint = self.enu2ned(frdy)
# check the flight ceiling, downward is positive
vehicle_height = self.vehicle.location.global_relative_frame.alt
if vehicle_height > self.flight_ceiling:
setpoint[2] = min(vehicle_height - self.flight_ceiling, 1.0)
elif vehicle_height < self.flight_floor:
setpoint[2] = max(vehicle_height - self.flight_floor, -1.0)
self.setpoint_msg = self.vehicle.message_factory.set_position_target_local_ned_encode(
# time_boot_ms (not used)
0,
# target system, target component
0,
0,
# frame
mavutil.mavlink.MAV_FRAME_BODY_OFFSET_NED,
# type_mask, addressed in reversed, and used to indicate which components should be IGNORED
# bit1:PosX, bit2:PosY, bit3:PosZ, bit4:VelX, bit5:VelY, bit6:VelZ, bit7:AccX, bit8:AccY, bit9:AccZ, bit11:yaw, bit12:yaw rate
0b010111000111,
# x, y, z positions (not used)
0,
0,
0,
# x, y, z velocity in m/s
setpoint[0],
setpoint[1],
setpoint[2],
# x, y, z acceleration (not used)
0,
0,
0,
# yaw, yaw_rate (only yaw rate used)
0,
setpoint[3],
